Joe »
https://forums.nicoclub.com/joe-u4941.html
Thu Dec 08, 2005 6:57 am
im assuming this is a RB25 going into a s13? next time post more info!
that plug looks like the one that goes into the dash harness on a skyline. contains fuel pump, ignition, cluster parts (tach, spedo, etc). the dash side is M63, harness side is F3 i belive. could be mixing them up. same plug on the S14 but wired differently.
the s13 dosent have that plug on the dash harness so it really dosent go anywhere. but you will need to cut wires off of it to make everything work
that is of course if this is the same plug were talking about here. its located on the main engine harness just behind the main ECU plug yes?
