Connector Help
Crizx
Car: 1990 300zx N/A
    Ok guys so I have a 1990 300zx and I found a connector that isn't connected to anything, anybody know which connector it is? There is another connector that looks like its supposed to connect to it but its different
    Crizx
    Car: 1990 300zx N/A
    They are located near the fuse box
    Crizx
    Car: 1990 300zx N/A
    Image Image
    z32loverboy
    Car: 1990 300zx CRP N/A 5 Speed (wreaked, now a shell) SOLD
    1993 Slicktop CRP N/A 5 Speed w/ '90 built N/A motor and interior
    1958 Ford f-100 straight-body (Grandaddies truck, resto-project)
    It goes to your TPS (throttle position sensor).
    Crizx
    Car: 1990 300zx N/A
    Thanks man
    z32loverboy
    Yeah, that's the gray one. The white one at the bottom is a body harness connector that goes to something or another. idk which you were asking about
    itsa300zx
    Car: 1990 300zx NA W/TT swap
    2011 Nissan Rogue S
    2008 Highlander SR5
    I don't think that grey connector in the picture is for the tps. Tps connector is a 3 wire connector, that one only has 2. I do not see a hood switch in your pic, that might be for the hood sensor.
    Crizx
    Car: 1990 300zx N/A
    Where would the hood switch be located, and thanks for helping
    Crizx
    Car: 1990 300zx N/A
    z32loverboy wrote:Yeah, that's the gray one. The white one at the bottom is a body harness connector that goes to something or another. idk which you were asking about
    I was wondering what both of them were since there just sitting there unconnected
    itsa300zx
    2011 Nissan Rogue S
    2008 Highlander SR5
    Crizx wrote:Where would the hood switch be located, and thanks for helping
    In your first pic, next to the shock mount. See the red nut on the empty bracket.
    Item B in the link
    http://z32.wikispaces.com/Theft+Warning+System
    Crizx
    Car: 1990 300zx N/A
    Ohh so that's it. Thanks for the link by the way
    DCaff300ZX
    Car: .
    1993 CRP TT- Modified
    Yep, it's definitely the hood switch connector as I removed mine as well, and have the same "extra" connector now...
    ThisIsSparTTa
    Car: 91 300ZX TT 2+0
    TPS has 3 pins. Hood switch has 2. It's in the right place for the hood switch. People remove them because there is no light under the hood, but if you leave the hood up, it will drain the battery.
