Talamascan wrote:Perhaps it is because you have a fairly new car with low milage, but if you only have a filter attached to the hose, I'm curious as to where the excess oil goes, because in my experience, there can be a significant amount of both gases and oil venting from the crankcases of most cars.
Perhaps. But you do pose a good question about where the excess oil goes. Maybe it is hot enough that most of the oil is pretty much vapor????? idk for sure.
Here is what mine looks like:
J30tChumpCar wrote:Based on this info you are definitely doing a disservice to the engine and yourself with your PCV delete proposal, heck I race a J30, it gets oil changes every 1300 miles and only deleted the system because it could not work properly in right hand turns under extreme G.
Between races I do see some moisture accumulate on the underside of the oil cap when driving short trips where the engine was not fully warmed, a side effect of no PCV, long term and with longer oil change intervals is where things go south.
I understand that it will cause problems in the long run if there is no ventilation. But isn't there normally a small port in the engine block that the hose is connected to? so if you were to remove the hose altogether, it will still be ventilated unless that hole is blocked. is that right or am I misunderstanding your statement?
