I have an idea I am very interested in pursuing but it involves requesting data from the ecu. I need to be able to access RPM information as well as the codes so I can send them to a mini computer I will have in my car. Basically I'm going to have a Raspberry pi 2 as a computer in my double din stereo that will access RPM data and change the color of the in car lighting when the RPMs increase. I also want to be able to access codes so I can access them through the Raspberry pi 2 unit. If you are not familiar with a Raspberry pi 2 please click this link...
https://www.raspberrypi.org/products/ra ... 2-model-b/
Also I have found PLMS cables and software to connect to the Raspberry pi 2...
http://twinchip.com/product_info.php?la ... plms.html&
So my main concern is, is this possible? To request data via obd1 or should I splice into the wire transmitting RPM data? Your reaponse is always appreciated, thank you for your time.
