Connecting IPOD to G37x sedan
Discussion forum for body kits, repair, modifications, interior styling, Audio / Video and internal/external lighting.
wilkie366
Car: Infinit g37x
Hi
I have a rented G37x sedan and I have a long drive coming up. question is how do I connect my Ipod Classic to this...i don;t see a port for an auxiliary input and only find the RCA inputs inside the armrest along with the power socket..any help will be really appreciated as I'm done with the commercials on the radio and would much rather have my iPOD on!
thanks!Bob
bgwilliams1977
Car: Infiniti G37x
if the radio has IPod control capability you should see a square plug next to the RCA inputs on the armrest. If this is the case, you need a special cable that connects to that square plug and into the IPod. Once this is done, you should be able to control the IPod from the radio controls.
If the car does not have this, you need an RCA to mini Jack cable, and just connect it to the IPod's earphone jack and the RCA to the red and white in the arm rest. Once you have done this set the radio to AUXiliary and you should hear the music through the radio.
Hope this Helps!
Return to “G35 and G37 Interior, Exterior and Audio”
