Yeah, that was my next thought. The only problem currently is that I installed it at the XM module in the trunk. I need to move it to behind the audio control unit so I don’t have to run a 10 foot AUX cable.Ilya wrote: ↑Thu Feb 15, 2018 7:42 amThe problem with a lot of these BT modules, especially the OEM one in the M's (newer ones) is that they don't get updated with firmware. So as phone BT firmware changes with updates, the other side doesn't. This is why people get crappy performance via BT.
My suggestion is to see if USA Spec. has an option for AUX and plug your phone in that way.
My Center Dash Speaker says Bose on it, so I believe I have the bose system, I don't have speakers in the seats howeverSstupid wrote: ↑Fri Feb 16, 2018 5:15 pm
Depends. Do you have the Bose audio control unit or the base model?
IMO, the best cable-solution for the Bose system is to just follow the YouTube video that shows you how to plug into the stock RCA cables that are under the rear seat console AC vent. You can use the stock systems AUX input. It doesn’t charge your phone and you have to run a cable but it’s a cheap solution.
The best BT-solution for the Bose system is the USA Spec BT45-INFI. Once I ran the unit up inside the car , I stopped having reception issues.
The best solution for the base system is the Audiovox Mediabridge. It has USB that acts as an input and charges your phone at the same time. The BT on the Mediabridge is for the birds so plan on using the USB.
So how well does the BT solution work for the Bose system? Does phone functionality still work well? Auto connect? Does anyone know of a step by step install walkthrough?Sstupid wrote: ↑Fri Feb 16, 2018 5:15 pm
This is what I currently use, and yes you're correct static on everything, Aux and even the regular radio stations, makes listening to radio stations even impossible. Wish Infiniti had just put a cassette player in the car then all we would have to do is buy a cassette converter and be doneTsowdsun wrote: ↑Tue Mar 20, 2018 11:45 amI have a 2006 M35, bought it used, but assumed that when I had BT that it was for more than just the phone. I have navigation in the dash and a DVD player for in-dash as well as the RCA plug ins from the back seat. I have bought a Scoche BT/FM adapter which I hate because I not only do I have static on the "open channels" but I have also noticed that my stereo has really poor reception in comparison to the other cars I own or have owned.
Does the 2007 M35 have an additional BT input beyond just for the phone?
