robbbby »
https://forums.nicoclub.com/robbbby-u1703.html
Fri Oct 24, 2003 9:55 pm
Alright I know this has been asked and answered many times but everywhere I read I hear different things.
I have been TRYING to set my timing by the method covered on phase2's site by removing the CAS and lining up the yellow dot with the mating mark. My question is when you put the CAS back in what marking is the crank pulley supposed to be lined up with?Phase2 says second from the left but from what I have read that would be 0 degrees since the marks on the crank pulley read as such from left to right
-5, 0 (yellow mark), 5, 10. 15, 20
If you set piston one to TDC it lines up with the 0 degree mark (2nd from left) will this set it to 15 degrees even though it is on the 0 degree mark? I have read elsewhere to set it up 2nd from right which would be the 15 degree mark. Can someone please clear up what marking im supposed to use and what position the 1st piston is supposed to be at when I put the CAS back in to set my timing to 15 degrees?
