KnotSoo »
https://forums.nicoclub.com/knotsoo-u12535.html
Fri Jan 09, 2004 10:09 am
I am attempting to install a head unit in my 1992 240SX. The car is not equipped with the Active Speakers system. There is no unit installed at the moment. This is what is visible behind the dash: a larger harness with nine wires attached, a smaller harness with three wires attached, a red/yellow stripe wire with a small black connector at the end, and four loose/snipped wires (lavender, pink, red, green). I purchased an installation adapter which includes: a larger harness with ten wires attached and a smaller harness with five wires attached. As you can see, the number of wires that are attached to the male/female ends of the harnesses don't correspond. Can someone please identify the four loose/snipped wires behind the dash and why the factory harnesses and the adapter harnesses don't correspond? Also, which wires are associated with the gauge clock and the dome light not functioning? I would really appreciate any input. Thanks!
