Jberger »
https://forums.nicoclub.com/jberger-u226.html
Thu Aug 14, 2003 4:33 pm
All fluids age with time, regardless of use.
Example, I've got a miata which is my "fun" car, it's used as my personal car and doesn't rack up nearly as many miles annually as the Q. Still, I change the oil every 3 months, even if it's only been driven 1000 miles. As the oil ages, the detergents begin to fail and the chemicals alter thier behavior. So all the combustion byproducts the detergents would have been collecting, began to become active again. The short trips cause a build-up of moisture, which can lead to rusting, etching, etc.
Gasoline can begin to varnish, leading to all kinds of problems for the fuel system, so changing the fuel filter is a good preventative measure along with keeping the tank stablized with an additive.
Brake Fluid is Hygroscopic, which means it tends to collect water over time, even if the system is "sealed" and that collected water will pool low in the calipers leading to rust. So I still flush them regularly.
I even change the radiator fluids annually, just in case.
It's good preventive routine which keeps the odds in your favor!
