LoserCard »
https://forums.nicoclub.com/losercard-u78523.html
Sat Jun 02, 2012 10:39 pm
Ok here are the tests that I have performed and I think I may have narrowed it down to my engine temp circuit or air regulator.
Test 1: Removed IAC and inspected and tested solenoids. PASS
Test 2: Unplugged IAC, FICD (AC Solenoid), TPS, and WOT sensors. Set idle to 700, set timing to 20BTDC. Idle screw screwed in about 1/4 inch (air regulator stuck open?).
Test 3: Plugged in TPS and WOT sensors. No change.
Test 4: Unplugged TPS and WOT sensor, plugged in IAC and FICD. Idle back at 1500 rpms.
Test 5: Unplugged engine temp sensor (ecu sensor), idle still at 1500.
So I am really considering that it is my air regulator valve because:
A. With my IACV not operating, my idle screw is almost completely closed. Meaning air is coming in fast from somewhere.
B. With my IACV operating, it seems like it is in an idling position except twice the amount of air is being let in from the air regulator.
C. I know this fact may not prove much, but I can lower my idle by squeezing the air hose that runs to the IACV and air regulator from the air intake hose.
So with all that, you think you guys agree that my air regulator is dead or do you think it might be my engine temp sensor circuit?
