confused...vacuum leak?
Craving4Boost
Car: 91 240sx fastback
i think i have a vacuum leak but im getting really confused...first off..i have a t3/t4...running 370cc's and a SAFCII with a plx wideband
all my charge pipes are hooked up fine...i saw these hoses under the throttle bottle that lead to no where so i took those off and put vacuum caps there...then i closed off the EGR tube...i get about 12in hg vacuum? is that correct?? shouildnt it be at 20?? when its warm it goes to about 10inhg....
the weird thing is...when i give a little throttle...the autometer boostgauge would actually go down to 20inhg instead of upwards to 0inhg...however when i give it a lot more throttle it will rise instead of going down....
on the SAFCII monitor mode i get .1-2% airflow which is wayyy to low for idle...it should be about .7% correct?
one VERY intersting thing is that when i step on the brakes repetitivley my idle would actually rise...then the idle is about to die...i keep pressin the brake and it would rise?? odd??
also i hear a HISSING sound around my turbo...could that be a vacuum leak?? or is it just the turbo..when i squeeze the FPR vacuum line the hissing noise disappears..when i let go it comes back...also when i squeeze the fpr vacuum my boost gauge goes to 0inhg...iono if that tells u anything i just wanted to add that fact...
help me out!!
Structure240sx
check ur brake booster line
Craving4Boost
its connected...however i did accidently bleed my brake lines without it being connected...but its connected now..ill probably rebleed my lines again
1WheelWonder
Car: 1991 Nissan 240sx
I had a leak in my brake booster line, which caused a low vac reading for me.
Craving4Boost
wheelwonder....my boost gauge isnt hooked up into my brake booster line though...its T'ed off my fpr
1WheelWonder
Mine is ran off of my fpr also.
Craving4Boost
intersting...how would a leak in the brake booster line cause low vacuum reading? could this also explain my weid issue of pressin the brakes raises my idle?
1WheelWonder
It's all controlled by vac the same vac that controls your bov, fpr...
Craving4Boost
alright ill make sure to check that out....could that be the HISSING sound?
virus77
Car: 95 S14, 71 240z, 97 e320
Structure240sx
thanks virus, that was the link i wanted to show just couldnt remember who and where i saw it
steven - the brake booster runs off a vaccuum. all the vaccuum sources come from the intake manifold. they will come from different places on the intake manifold but its all from the same source
Craving4Boost
is pressin brake pumping vacuum or something? is that why my idle rises while pumping my brakes? its pretty funny when my idle is about to die im pressing my brakes instead of my gas..lol
geez anthony go take a nap you never sleep
