tomi240sx »
https://forums.nicoclub.com/tomi240sx-u11909.html
Tue May 02, 2006 9:30 am
I already searched but still kinda confused about the situation. I know that th rb25det is an interference motor and that when changing the timing belt everything needs to be at TDC. what happen when everything is at TDC when I took the belt off, but when I tried to put it back on, the cams pulley moved from the TDC to about an inch or 2'oclock to 3'oclock. Both pulleys moved about an inch at the same time. I thought I couldn't moved the pulley so I put the belt on where I marked it and everything back on. once the crank pulley was back on, I tried turning the crank and it would turn smoothly for about 270 degrees before the smoothness became rough (I really had to tried to turn it). my brother (honda tech) said it's because of the spark plugs being in it and that if I take it out, then roughness would not be rough but back to smooth. I'm thinking that I messed up because of the cams pulleys moving, did I? If I did, how can I fixed it? also I know I should do a compression test but will a compression test hurt it (if I have bent a valve)? please let me know if I can take the belt off and tried to realigned everything (I'm thinking that I can't because of it being an interference motor and that you are not suppose to move anything when the belt is off.)thanks for your input.
