confused on wiring for 91 240sx auto to manual swap
budfan3815
Car: 91 Nissan 240sx
I am a little confused on the wiring for the auto to manual swap on my 91 240sx. I just want to be sure before I get into this and have to stop. From the way I read it the wiring from the inhibitor switch the green/white wire you can splice into the reverse sensor on the transmission and the green/blue, it says to run it to a reverse plug wire, but I dont understand the reverse plug wire that this is referring to. I have searched all over so I wouldn't have to post ,but I have had no luck. PLEASE HELP.
sil_fourty
Car: 93 240sx coupe
Don't worry about wiring. the only thing you need to be concerned with on this subject is simply swapping the speed sensor, and disabling the neutral/park safety circuit. This is done by looping the black and gray wires that lead from the right/passenger side fuse panel at the front of the engine by to the transmission.
I did this about 2 years ago, and have never had a problem I don't have anything hooked up to the transmission other than the speed sensor.....this means you won't have a speed cut, but also means the rev limiter may also be disabled, I don't know for sure, because I don't get that close to redline because I love my car.
vancouverbc
Car: 1991 240sx
isnt the reverse sensor just a switch? wiring diagrams in tutorial link
look for back up switch in the followin diagram. its in the middle of diagram 34c.
http://img264.imageshack.us/my...4.jpg
budfan3815
thanks guys. found evrything i need. appreciate the help.
