Confused on Throwout bearings.
Flipzide
Car: 1989 240sx SE & 1996 240sx
I've been trying to research if a throwout bearings are different on different year KAs or the same in all. So far every thread I've searched has not been consistent on what is what.
So are the throwout bearings the same on all KAs from 89-98 or are there differences I should know about?
funigui
Car: I HAD a 1991 240sx coupe. woked NA motor. ran like 14.5 ish. blew it up @ 140 after an ECU reflash.
there the same between generations for sure. 89-90 91-94.. 95-97 97-98... however since they all use the same trans and motor, its a fairly safe assumption there all the same. Im running a 95 trans on my 90 using a 90 clutch and bearing if that helps any.
