KaZ (VaBch) »
https://forums.nicoclub.com/kaz-vabch-u11666.html
Fri Oct 22, 2004 2:17 am
Most vehicles w/ a US boost gauge (i.e. not metric measurements) should be around 20 in/Hg at vacuum... my '84 200SX w/ a CA18ET reads 20in/Hg at idle...
My Sunpro Boost gauge sits like that, touch under 0 when off... and reads 19/20 at idle, and 20+ during in gear deceleration... I've seen boost as high as 12psi before (cold weather spikes). You definitely have a bad vacuum leak SOMEWHERE. Might want to try and pressure test it... You can fab a plug w/ a air compressor line nipple on it, and if you know someone with an air compressor, buy an air regulator and set it for 10psi, then let the air into the system... you'll hear it hissssss.... =)
