InsanityInc »
https://forums.nicoclub.com/insanityinc-u19073.html
Sat Jul 22, 2006 7:23 am
First question, for the exhaust:
A large exhaust system can never make you lose power over stock, except in the rare instance that your factory system is already well tuned (350Zs are like that).
To understand why a smaller pipe can produce more power for a given car than a larger one, you need to understand something about engine airflow as well as the venturi effect. The venturi effect is something based on the bernoulli principle which is a physics equation that states as the velocity of a fluid (gases and liquids are fluids) increases, the pressure across that fluid decreases. This is also why a syphon works. The venturi effect is an extension of the principle which states that a fluid forced through a smaller opening will increase in velocity, therefore the pressure will decrease. The operation of a carburetor relies on this. Therefore, a high exhaust velocity will decrease backpressure (often into negative pressures, or a vacuum, actually assisting exhaust scavenging as opposed to impeding it).
However, there is a trade off. A pipe that is too small will impede proper flow and increase backpressure. This is because any given opening can flow a given CFM of a gas at a given pressure. Therefore, if your pipe at 0 pressure cannot flow the amount of air your engine is producing, the engine will be forced to pressurize the exhaust until it can travel through the pipe.
So, you have a bit of a dichotomy. A smaller pipe can increase velocity, which can decrease backpressure into negative levels (the desired result), whereas too small a pipe will simply cause too much backpressure to possibly be negated by any velocity gains. A really huge pipe will have 0 backpressure (cooling gases can't cause backpressure, it's simply impossible) as it will be fundamentally the same as running an open header. However, 0 backpressure obviously isn't as good as negative backpressure which is why precise exhaust tuning is important.
Probably more than you ever wanted to know about that, but there you go.
As for the large vs. small intercooler, it's somewhat related to exhaust size but not all that much given that the purposes of the devices are different. However, there is a similar dichotomy. Essentially, a larger volume of air (larger hot/cold pipes and intercooler) take longer to pressurize, and also will not reach as high of a pressure (remember, pV=nRT, so if V is bigger and you're still shoving n moles through, then pressure has to drop). So, a larger intercooler and hot/cold pipe will make your overall boost pressure decrease across the pipes as well as increasing turbo lag. A smaller intercooler (or lack thereof) will do the opposite. However, the problem arises when you consider that a larger intercooler will cool better than a smaller one (generally speaking), meaning that even though your pressure might end up lower, you still have a more powerful intake charge.
So, the tradeoff here is that your turbo lag is increased, your throttle response is decreased and your power is increased as you go to larger and larger intercoolers.
