C-Kwik »
https://forums.nicoclub.com/c-kwik-u426.html
Wed Apr 09, 2003 8:17 am
Well, while it can't be calculated, you can make an educated guess. Figuring that most DOHC motors make anywhere from 85-90% VE, use a number in this range at the torque peak. Then kind of work backwards and calculate what torque would be at that that RPM with 100% VE. Using this as your base torque I'd use a dyno chart to determine torque levels at the RPM points you want to plot. Then calculate the percentage of difference between the base torque figure you came up with, and the torque on the dyno at that RPM. That percentage should be somewhere along the lines of the engine's VE. There are certainly other factors, and this is by no means totally accurate, but would be a better reflection of VE than using some arbitrary number all the way across the board.
