squeefoo wrote: I just can't believe that they have been on there for several years now and the car didn't self-immolate from those non-OEM parts
From Q45tech, perhaps a more astute observer of experimental evidence:
"Oh! I started out with urethane till I bent two sets of end links [the heavy duty ones supplied with bar]. Then I tried various combinations of rubber/urethane finally all rubber.
The problem is the 4:1 reduction 1" of wheel movement is only 1/4" of movement at the end link......very very hard to make a fine adjustment that stays the way you want it.....what happens is nothing then wham a sudden stiffening which will cause a lack of smoothness and snap oversteer with rubber bushings. Severe oscillations when you whipsaw the steering again due to the inability of shocks to provide adequate control over something twice as stiff as they were designed for!!!!!!!!!"
Grok?
