COnfirmation on parts for RB25DETNEO rebuild
TimTurboZ
Car: 95 S14 w/RBXX... 65' Mustang GT
I'm about to begin building an RB25DET NEO. It can be quite difficult to find a direct answer on forums/online for info on the NEO6 motor as you know so I wanted to confirm/check on a few parts.
As far as hardware I'd use: ARP Main and Head Studs that are all the same on RB20-26 motors, and for the rod studs I'd use the RB25/26 Specific studs because the NEO's use the same connecting rods as RB26's. I have that correct???
For rod bearings if I choose ACL I would need the RB26 bearings *again same rods*, but for the main bearings (crank) would I go with the 25 or 26? (Raw Brokerage's site lists Cosworth main bearings as 25/26 (same part) but ACL lists RB20/25/30 (separate part #'s) but no RB26 tho I;m sure I can find them elsewhere)
Now I know NEO pistons are different then normal 25's but I haven't read any info about what rings I would go with, any recommended parts/interchangeable RB rings that I could use would be appreciated. I will only be honing my cylinder walls and using whatever the stock size is.
Thanks in advance for any help you can give me! I've been researching alot and have been trying to wait before I started asking questions lol.
Tim
I'll post back with a few more questions later I'm sure. I email Raw Brokerage but no reply as of yet
TimTurboZ
ACL does have RB26 main bearings *my bad* still need to know if I'd go with 25 or 26 bearings tho
mixeds14
Car: 240
u may want to get in touch with carlH, i believe he help rebuild a neo with one of hes friends from what i have read, also sickness14 i believe, i might be confused him with someone else that has a similar name, he has a build post on here somewhere........
TimTurboZ
Yeah I've seen a couple rb25det neo builds but just listed in ppl's sig's. I PM'd 1 guy no reply :( Raw Brokerage hasn't responded either. I'll try carlH tho I know he's the guru
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
Sorry that you didn't get a response.
If you can shoot me an email direct and I'll see what I can do.
[email protected]
neonbomb
Go on SAU. All of this information is there.
MarkS14 (forget his real name) is good with Neo knowledge. As is Carl.
sickness14 bought Bumblebeetunas Neo, so he may have learned alot from that big mess of a motor.
