mdb4879 »
https://forums.nicoclub.com/mdb4879-u186863.html
Sun Mar 31, 2013 1:04 am
I'm pretty sure, but not certain, on this so I just want to be sure. Pretty much the only major differences between the FWD CA's and RWD CA's is lack of a crank girdle and oil squirters, and the piston dome (compression ratio) is different on the FWD's and a different intake cam for the CA16, correct? And maybe the CA16 head may be different somehow? (valve covers are different, too)
So if I was able to pick up one or several FWD motors for cheap would it be worth it just to have spare cranks, rods, and heads? Plus I guess there's also coil packs, CAS's, and maybe a few other electronic odds and ends?
