Confirmation needed - AVCR installation
vutony
The avcr is going on a s13 sr.....so the pressure sensor connects to intake mani......and solenoid vavle; COM goes to actuator, NC opened, NO to intake mani and cold pipe, rite ?? and which port do i connect the bov to?
thanks in advance
inertiadrft
Car: Do NOT be fool'ed by the low post count, The wise choose silence over Bla Bla Bla...
[com] = actuator, [no] = hot pipe, or cold pipe but not the intake manifold, [nc] = opened, and use the two intake manifold nipples as follows........ top right small = pressure sensor, top left big = blow off valve,
hope this helps......... dont forget to cover the hole on the intake pipe where the stock [solenoid valve] return hose goes!!!
vutony
thanks........its odd that how the bov is not connected to the solenoidd vavle......my last boost controller (hks evc v) did
