BBISHOPPCM »
https://forums.nicoclub.com/bbishoppcm-u54071.html
Sun Jan 18, 2009 7:56 pm
Alright, I apologize for the above post. I did some research, and I see that these kits really do exist. Their benefits are iffy... especially on a modern engine. I am curious, how did you alter the readings given off by the MAF to "trick" the computer to compensate for the additional air (hydrogen) introduced after the mass airflow sensor? Otherwise, this is really a "vacuum leak," and will definitely throw off the mixture. Also, how certain are you that your hydrogen generator is putting out a steady stream of hydrogen that is properly diffused in the intake air, and is properly metered in the proper ratio (in relation to the throttle position?) Also, how can you verify the purity of the hydrogen produced? There is a very simple device you can make using a pickle jar, water, two copper electrodes, and a 30vdc power supply that makes "hydrogen," however, this isn't pure hydrogen, and the flammability is totally unregulated (it can either explode, or just enhance the flame from a candle).
