spitz7985 wrote:Wouldn't my check engine light be on if my ECU had trouble codes?
O, I thought your ECU light went on, hence trying to reset the ecu.
Only times I had bad idle when installing new stuff was when the light went on.
However, there's techniques to reset ecu on teh 240sx.org site if you look under the ECM section.
If your maf sensor was reading bad, it should also throw an ecu code.
So, if it's idling bad and all you did was put in a cone filter, w/ no codes being thrown afterwards, I'm kinda lost.
Try putting the original back in and see what happens.
