Loungelurker »
https://forums.nicoclub.com/loungelurker-u235149.html
Tue Jun 10, 2014 7:10 am
The climate control is a little tricky. Mentioned above was that if it is on "Auto" your AC will kick in as it sees fit based on the temp you set the climate control at. The AC button will not light up. What I am finding is even if the "Auto" isn't on, and the "AC" isn't on, the AC is actually still running when needed to keep the temp at what ever you have it set at. I thought it would just run the fan. I guess not.
This is the first vehicle I have where the Climate control does this. Is there any way to run the fan with out the AC running? I know it was 80 yesterday. I had the climate set at 70, but the auto and the AC were off. It was very cold air coming from the vents, so I know it wasn't just the air from outside. The other tell tale sign that my AC was working was that after I parked my vehicle there was the condensation puddle under the vehicle.
