ZGadson »
https://forums.nicoclub.com/zgadson-u56225.html
Thu Oct 23, 2008 5:04 am
They didn't seal up the headlight well enough. I took out my amber corner inserts and had the same issue. Had to take the whole housing apart a 2nd time to make sure I sealed it everywhere. I also drilled several small holes in the bottom of the clear lens to allow water/condensation to drain. I drilled 6 or 7 small holes along the bottom of each light from end to end. You can't see the holes, and it seems to be working great. Its been almost a year now, and no build up inside.
-Zach
