concerning butterfly removal, 91-94 KA
tramp_drift240
Car: 1992 240sx SE Coupe
after the removal of the intake manifold butterflies, would there be a "vaccuum leak" if the holes between the runners werent filled/plugged?
when i rebuilt my KA in the spring of 07, i removed the butterflies, but only plugged the hole to the atmosphere, i left the holes from the rod that ran through the runners. would that cause a high idle?
Chris28
Car: 92 s13 KA-T
I don't think so, all the write-ups I've read haven't said anything about the inside rod holes. Check all your other vacuum lines for leaks.
Bigvinnie
Car: 2004 Nissan Frontier desert Runner, 2014 Nissan Titan
[QUOTE=tramp_drift240]after the removal of the intake manifold butterflies, would there be a "vaccuum leak" if the holes between the runners werent filled/plugged?[QUOTE]
It wont leak, but it will disrupt the intake velocity between the runners. It is best to seal the holes with JB weld. I've done that to a few of them for hine and extruding.
