Buzzman »
https://forums.nicoclub.com/buzzman-u55955.html
Thu Aug 30, 2007 6:40 pm
I wouldn't worry if I were you.I have 3 Nissans. An 06 Altima, an 02 Pathfinder and an 03 Sentra SE-R.
The Sentra came with fog lights, but I installed fog lights in the other 2 vehicles.The fog light switch you are concerned about is not really a separate rocker switch or anything like that. You also don't need to run any wiring. These cars are all pre-wired for fogs.There is absolutely NO work done to the dash. Totally unnecessary.The fog lights are turned on by a twist actuator which is part of the headlight switch/signal light stalk on the left side of the steering wheel.All that needs to be done is the existing stalk is changed out for a new one that has the fog light switch. It is a complete assembly that takes 5 minutes to replace. Piece of cake. You could probably do it yourself and save a few bucks. Hope this helps to put your mind at ease.By the way, if the dealer gives you a big song and dance about having to take stuff apart, or, like one guy told me, having to pull the steering wheel to install the switch, then he's either ripping you off, or he's never done one and hasn't a clue.
