mileagecheck »
https://forums.nicoclub.com/mileagecheck-u163908.html
Wed Jul 07, 2010 10:25 am
I operate a Nissan Quest and am saving up to 22% on gasoline usage with "Mach 3 SEFS-HD" - an ECO FUel Saver/Performance Enhancing Reformulator which (as a Distributor) we calin saves 13%+ gasoline and 16%+ diesel and bio-diesel ... and only standard fuel is required as Mach 3 octacne level is approaching 100.
The vehicle has increased power and accelerates better on hills, plus the fact that it helps the Environment!
My blog:
Mach 3 SEFS HD" saving fuel and the environment ...
To whom it may concern: We would like to introduce our ECO Fuel Saver / Reformulator ..."Mach 3 SEFS HD" - (Mach 3 Super Efficient Fuel Saver High Density) - that is specially formulated to improve the performance of diesel, fuel oil, bunker c 180 or bunker 360 heavy oil (requiring blending arrangements) for heavy duty diesel piston engines, electric power generators, marine diesel turbines and external combustion furnaces & boilers with power output exceeding 400 HP. (for industrial or transportation uses) .. 1 oz (30 ml) of Mach 3 SEFS HD blended with 15.63 gal (60 L) of diesel fuel or similar (1:200 ratio) will produce lower emissions ( -7% HC, -33% CO, -44% NOx, -1% CO2 or 17%), more engine power, smoother running and the potential for consumption reductions in excess of 16%. It will also help to remove carbon deposits for improved performance, longer maintenance intervals and longer engine life. Mach 3 recommends a 2 oz (60 ml) per 15.6 gal (60 L) of fuel (1:1000 ratio).
Product can be ordered On-line FOB Contact us for details!
Distribute this product - Purchase at Wholesale prices.
For all other information and comments, please contact Hugh @gaya$sspammer.com
Your comments are appreciated!
Hugh Love - Representaive
mileagecheck on Thu Jul 08, 2010 11:22 am, edited 1 time in total.
