Oh I'm replacing an old/cheap sony pro-logic 60x4, or so it says. I noticed a HUGE difference with my new receiver! Much more powerful, the amp has a LOT higher dampening. It controls my speakers much better for tighter, less muddy bass Did I mention the 7.1 surround?PoorManQ45 wrote:Very Nice! http://www.pioneer.co.uk/uk/pr...62-98120W RMS x 7 ! Holy crap. That's alot .
But of course, mine is bigger then yours . 150W RMS from an old Sony A/V receiver .
What speakers are you going to hook up to the receiver? Please don't tell me that you are going to use one of those Home Stereo in a box Cube things .
If you do, I will have to beat your a$$ for buying that nice receiver, and then hooking it up to crapping speakers. BTW, even Bose and Klipsch cubes arn't any good.
If you'd like help with speakers, I can help you out . Do you prefer 18in or 21in sub in your speakers
Aww you rat bastid! I've been keeping my eye out for some S412's and S312's. Also some acoustic research AR1's. I've been wanting some for 5-6 years. Probably the best towers ever made, for the money.Rex wrote:Here's the JBL (Studio Series 312) that I got for $135 for the pair. One cracked grille, one scuffed corner.
Click on image for specs.
I say get replace all of those speakers that you mentioned except the CV LS-12s.Looneybomber wrote:What's horrible is that my speaker selection isn't the greatest. I have a pair of cerwin vega LS-12's and an LS-6c as my center. For my surrounds I'm using some old sony 1-way bookshelfs I really should have jumped on the deal with the Infinity Alpha's being sold for half price in Crutchfield but I wanted to use my 1k on a carpayment instead
What do you mean by this?HashiriyaGDB wrote:Oh, and don't ever, ever, ever, EVER have more speakers than you have channels of sound (subs excluded)....
Tisc... Tisc... You under estimate the Intellegence(note incorrect spelling) of PMQ once again. Ya'll should be ashamed . There is a way to adjust the Voltage and/or wattage going to the rear speakers. On the Pioneer A/V receiver it has a feature to either "boost" or "Cut" the power a little going to the surrounds.Chingon wrote:I wouldn't say that 5 towers or 5 identically sized speakers is the best option for surround sound either. By the way dts and 5.1/7.1 are encoded, using similar sized rears would overshadow the fronts in a crappy way w/o a way to control voltage and wattage output. If you are just into stereo this is perfectly fine however.
Well then, we need alot of bass. The living room is "huge". 36ft x 26ft 14ft vaulted ceilings, and an open floor plan. So the volume of the room is actually much larger then 36x26.HashiriyaGDB wrote:You only need so much bass, one really really good 15" HT sub is as much as anyone's going to need, unless you're filling a gigantic room with sound.
Well, to correct the imaging problem, you have to make sure that all the speakers are equally distant from the location in which you will be listening to it most. As long as all left channel spekers are within 3ft, and all right channel speakers within 3ft, then imaging will not be a problem.HashiriyaGDB wrote:As for the speakers per channel of sound thing:
Some people do DUMB stuff, like have 4 front channels. i.e. A/B speakers on a reciever, and 2 speakers are playing the same channel for no good reason. This should never be done, if someone thinks their front channels are lacking, they should buy better ones, not just add more speakers. Even if they are 4 of the exact same speakers, it STILL shouldn't be done, as while it won't conflict, it will throw off the imaging.
I had a guy in my fraternity that had 3 pairs of speakers, all playing the same 2 channels of sound. He thought it was cool because it looked like a stereo store. He's a retard, it sounded terrible. It was all mis-matched, the imaging was thrown off, etc... Stuff that is recorded in 2 channels (stereo) should be reproduced in 2 channels, not some half-assed quadrophonic mistake. In turn, if something is recorded in 5 channels, you only need 5 channels to play it back. You can have a sixth or seventh speaker hooked up, but nothing should be coming out of it.
