Computer software with car vitals/info
ATpossible
Car: 1995 Nissan 240sx
Ok guys first I'd like to say sorry if this seems like dumb question or has been answered but I can't seem to find any info at all while searching. My time is limited with school and work...like right now my boss needs me to do something (ofcourse) lol. Anyway thanks 2 anyone willing to help.
I was looking into info or where I can get computer programs that give info on the car like different gauge type info...oil pressure, temp., etc...Stuff like that. Kind of like a program (ie windows media player) that you download to a pc then connect it to "ecu/or something" and get info like that.
Thanks
slavetothemuzic
Car: 1991 240SX Fastback
I believe you're talking about something like Nissan Consult.
http://cgi.ebay.com/ebaymotors...ZWDVW
Chaos the Xile
Car: 1974 Datsun 260Z
Can the Consult be used with RB-series motors? All I see SR, GA, Ca and VG??
slavetothemuzic
Chaos the Xile wrote:Can the Consult be used with RB-series motors? All I see SR, GA, Ca and VG??
Not sure if there's a difference in the SW, or the connection cable, or maybe none at all, but here's one that says for the RB.
http://cgi.ebay.com/ebaymotors...wItem
I was just giving him a start point.
ATpossible
wow thanks everyone. That is pretty much what I was looking for.
Question about it tho...? It sounds like it can be used while driving but doesn't actually state it, so can you drive while checking the "stuff" out. Also where else can I get it? Or is this a good company?
Final questions? has anyone used it before or owe one of these programs? IF so how is it? Worth the money?
Many thanks. Seriously! Thank you guys...u the best
slavetothemuzic
ATpossible wrote:Question about it tho...? It sounds like it can be used while driving but doesn't actually state it, so can you drive while checking the "stuff" out. Also where else can I get it? Or is this a good company?
No idea. I haven't used it and don't plan to. I would say if you want to buy it from that seller, look at his feedback to judge if he is legit.
As far as if you can use it while driving, someone else will have to step up and answer that one.
BoostFab
Car: S13cp, S13fb, S14z
you need to make sure you have the DDL connector so this cable can plug in to.
sr240dett3
Car: 92 S13 + RB25 + Silvia Front
Yes, You can drive and run this.
I know it has like a data logging feature.You can get a "Serial to USB" adapter to run on most laptops.Then there is a software you can install.
http://www.plmsdevelopments.com/consult_if.shtml
There not very expensive. But your other options are to get a Engine Management System.
Good luck, hope this helped
Consult Site wrote:
It includes the following features:
* Compatible with Win98SE, Win2K, XP and Vista.* Real time monitoring of RPM, speed, injector pulsewidth, injector duty cycle, TPS position, AFM voltage, speed, idle valve opening %, IGN timing, coolant temp, battery volts etc. All displayed on nice pseudo-analog gauges.* Data logging on all parameters with cool inbuilt replay feature.* Read and reset fault codes* Active tests like “power balance” (knocks one cyl out at a time), fuel pump on/off, VCT control, temporary changes to values for coolant temp, IGN timing, AAC valve (for idle adjustment) etc.* ROM read* More great stuff!
Kansei240sx
Car: S13 - RB25 Circuit car
71 240z - street/track day car
AE86 - Daily Drizzle/track day car
Z31t - Paper weight/street car
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
I use nissan datascan on my other Nissan. You have to wire up your consult port to make it work on your RB swap. It's a very good tool, it will even maptrace your ECU so if you have to burn a rom and you don't have a emulator you can see what cells are effected. I love it.
ATpossible
DDL connector? is that the cable that comes with the program?
Any serial to usb adapter?
Yellow4g63 wrote:I use nissan datascan on my other Nissan. You have to wire up your consult port to make it work on your RB swap. It's a very good tool, it will even maptrace your ECU so if you have to burn a rom and you don't have a emulator you can see what cells are effected. I love it.
how long have u had it? where did u get yours?
Yellow4g63
ATpossible wrote:DDL connector? is that the cable that comes with the program?
I got it back in June of 06. I didn't get it for my RB tho since I already have a PFC. Got it for my NX since I make my own roms. here is an example of the maptrace
