240sx88 »
https://forums.nicoclub.com/240sx88-u30524.html
Sat Apr 22, 2006 1:32 pm
yes i have a check engine light on, the problem is this, the motor shakes like it miss fires, it wont idle at all any more unless i give it gas (Ex. when i come to a stop light i pull my e brake slowly to slow down will i pump it with gas.) I had an ecu check done at the local shop. The ecu said the crank angle sensor COULD i repeat COULD be bad. so my question is this. With the symptoms i just gave u could it be the crank angle sensor and if so where is it located, how do i know if its bad, and how much to replace???
