computer and chip mods
Nissan 350z / Nissan 370z general community discussion forum
jfairladyz
Car: 2004 nissan 350z
ok so i looked into it and the e-manage is not that expensive and i found a shop that specializes in tunning. Now i wanna see about chips for the car. Is uni-chip the way to go?
ZBAZ
Car: 2003 350Z Touring
I am running a 2 position Unichip and find it to be pretty great!! The performance end of it uses way more fuel than the softer side of the chip. On the weekends or whenever you want for that matter you just flip the rocker switch and BAM!! WoW it lights up the Z and the softer side is still a big improvement to the stock OEM PCM programming. The UNICHIP was a 5 minute install and removed the REV limiter right off the bat and as far as speed limiter I have not tried it yet. On the soft side my fuel economy went up and the power chip side it goes down.
Great product.
BAZ...
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
not sure why you'd want a chip in conjunction with the enmanage, seems it woud just make tuning more difficult, and if you get the base emanage you'll want to spring for the optional timing kit, or just spend a bit more for the emanage ultimate
Return to “350z / 370z Discussion”
