Compressor
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
rocko715
Car: 2008 Armada LE
I just bought a 2008 Armada and I have a couple questions. is the compressor supposed to be sort of loose? How often should it run? Should the bags on the air shock be deflated after sitting overnight? Thanks for any input you all have.
PapaSmurf2k3
Site Admin
Nope, the bags should remain pressurized. The compressor should be tight, with a boot over the top of it. It should really only run once in a great while, or if you load the car up with a lot of weight (so it self-levels).
Sounds like you may have a leak somewhere.
rocko715
Car: 2008 Armada LE
Ok, thats what I thought, it has a boot over the top but rattles while running. Thanks for the response, that's what I was thinking too, but i just wanted to make sure.
PapaSmurf2k3
Site Admin
No problem. Welcome to NICO!
Return to “Armada Forum / QX56 Forum / QX80 Forum”
