Compressor surge is my friend
rudee023
Car: '03 Infiniti Q45
How long would you guys personally go without a blowoff/recirc valve? My motorset didn't come with one and my hotpipe and HKS SSQV are on order. Phase 2 was supposed to get their shipment in last friday but they still haven't so I haven't been driving it. I am currently breaking in my clutch so I am going wasy on the car. Any opinions? I do have a second car but it's a truck :( and not as fun.
Hijacker
Car: '92 240sx Convertible
'94 F-150
i wouldn't. it's possible to go without one, i guess, as long as you don't boost too high, but i wouldn't risk it.
S13240
You won't have any ill effects for driving it hard or daily without a bypass valve at all. Some turbocharged cars dont' even come with a stock bypass valve at all.
Hijacker
'94 F-150
i guess that's cause we have bushed stock turbos and not ball bearing turbos?
still I wouldn't push my luck. i know i would break something.
hokiruu
Car: 2012 INFINITI M37X Platinum Graphite
'95 240sx/s14 SR20DET (in 2000) SOLD
You'll probably be okay for a short period of mild mannered driving. Just tame your ego when some ricey DSM is beconing you. I took the first BOv solution I could find for cheap. Don't wait too long for that stuff on backorder, though. Give it a few days to a week max, then make sure you have decent valve in the mail.
S13240
tenkawa_akito wrote:i guess that's cause we have bushed stock turbos and not ball bearing turbos?
Does not matter, for instance, all trac turbo celicas and starions do not have stock bypass valves and they don't have ball bearing turbos.
RobDET
Car: Cars
Turbo Buicks have been BOVless for at the verry least 17 years now. Just a point to ponder.
S13240
RobDET wrote:Turbo Buicks have been BOVless for at the verry least 17 years now. Just a point to ponder.
Another point made, driving without a bov for a while wouldn't cause any damage.
Supafly
driving at higher than stock boosts on each respective turbo can have ill effects on the turbo from the surge loading up the thrust bearings in the turbo, and of course other PITA problems like popping off IC pipes and stuff. i did a mountain run with stock 7psi on my SR and no BOV, and i popped the IC piping off twice. car dies which = no brakes and no steering (at least power assisted). not fun at all.
RobDET
Car: Cars
Supafly wrote:driving at higher than stock boosts on each respective turbo can have ill effects on the turbo from the surge loading up the thrust bearings in the turbo, and of course other PITA problems like popping off IC pipes and stuff. i did a mountain run with stock 7psi on my SR and no BOV, and i popped the IC piping off twice. car dies which = no brakes and no steering (at least power assisted). not fun at all.
True... You definately have to make sure the pipes are on tight. It's bad business when they blow off at a bad time!
loudbay
Car: duh
funny thread.... i just had the plastic nipple on my old skool hks valve break off, and the ic pipe blew off imediately... damn 200 for a new one.... but much nicer
stumpz
i know people that have driven around for approx a year w/ compressor surge..
Cyberkreig
Car: 1993 Nissan 240SX SR
When i set my BOV spring too tight my IC>TB pipe pops off.. man that sucks..
loudbay
Car: duh
i think that's cool....
