CA19DET wrote:I dont think our engine perform at 90% Volumetric Efficency
when i was working it out i think i used 70% like SCC, one of the issues has them testing compressor maps for a 1.8 VW, just use the same calculations as they did, i'll check my magazines and post.
"For Volumetric Efficiency, we can assume 90 percent, which should be typical for this modern five-valve DOHC engine. Of course, the actual volumetric efficiency will vary from one engine to another and from one rpm point to another, and even depending on which turbo you use, but that's what makes this a simple model." -- page 160 "Sport Compact Car", June 2003
..and they are talking about the 1.8t vw
90% VE is also used in the "Honda/Acura Engine Performance" book by Mike Kojima.
So while it may be a stretch, i'm just assuming 90% based on these two and a few other publishings i've read. So realistically it may be very well more near 85%, i'm still giving the ca18det the benefit of the doubt because its still quite an advanced peice of engineering regardless of its age.
