compressor housing gasket?
wild_maxx
Car: 90 TT pearl yellow z32
i have noticed that some compressor housings have small rubber gaskets in them but mined doesnt. is that a problem? also, my turbo was originally internally WG but now external. there are brackets that surround the housring holding it onto the turbo but the internal WG assembly was part of the braket setup. would it be ok to use washers under the bolts to hold the compressor housing on? i need to use 3 of them.
Structure240sx
seems like washers would hold up fine doing the same thing. i would try to get some brackets tho
my new turbo has that rubber ring/gasket on it
my old turbo did not
each boosted fine
wild_maxx
any idea as to where i could get some brackets? i have been searching around for about an hour and cant find anything.
