Compressor for strut springs
Wilbursan
Car: 2006 Infiniti M35 Sport
I've seen some on Amazon that have pins to help hold the springs in place so they are less likely to pop loose but I don't know if they will work on my car. For you guys that do this at home, what kind of spring compressor do you use?
2006 M35 Sport
ae7456t
Car: 2006 M35X with 19X,XXX miles
I am sure there are others, but I think they all operate under the same principle, so here is the one that I used for my M35X...
https://www.amazon.com/MacPherson-SPRIN ... essor+Tool
$35 from Amazon is not bad, and it seemed to work pretty well. I suspect that you local auto parts store will likely loan one to you for free, if you are so inclined.
Good luck!
bicsintegra
Car: '06 Infiniti M35
'06 Infiniti G35 Sedan (daughter's car)
'11 Ford F-150 FX4
'13 Ford Edge Sport
2020 Infiniti QX 80
that is the exact same one I used to do my M35, worked with no problems.
AlabamaDan
Car: 2015 Infiniti Q70
1998 Infiniti QX4
I got mine from Advance Auto Parts or one of the other parts store. They have a tool loaner program. They looked just like that only..... no cost.
