joevanni wrote:thanks for everything everybody and the engine was in the car already when it was making that noise,i got the car for 500 buxx and i knew about the problem but i thought it was a simple fix but now the noise got worst i think the valves are slapping the piston so im just gonna swap it with another.
its not a total waste thou bro.....it can be rebuilt..and for what ya paid for the whole car..it might be worth it...not only that..but you will get a greater understanding of how your motor works,feals, sounds and runs...this is a huge advantage in the long run...even if you have never rebuilt an engine, its worth the time to learn if only for the advanced knowlage of when an issue arises that is criticle..but not fatal to the motor...or...when you have minor issues that can potentially become like this one...if your timing chain issue was addressed by the old owner early on..you would have a good running car now...so take the time..rebuild this one...and become leet!..
who knows..you might end up the next sought after tuner in your hood...and maybe..it would spark a direction you never thought you would take before...good luck..and if ya need help..we are all here to help ya along the way....aint nicco grand!
