Compression testing the Ka24e
aogoblomi_03
Car: Making my car go faster
What #'s should I be looking for when I do a compression test on the ka24e? I have heard 150 for the ka24de, I know it is probably not the same! But is 130 good? I don't know ??? Your response is greatly appreciated.
TrunkMonkey
Car: 2000 Lincoln Navigator
aogoblomi_03 wrote:What #'s should I be looking for when I do a compression test on the ka24e?
192psi (standard)142psi (minimum)14psi difference limit between cylinders
-demetrius
DAEDALUS
Car: 1990 Infiniti Q45
130 is low. Did you have all the plugs out AND the butterfly valve wide open?
aogoblomi_03
By butterfly valve do you mean the throttle body or what?
TrunkMonkey
when you take a compression test, make sure you have all the spark plugs out, the fusible link for the fuel injectors removed, and the accelerator pedal fully depressed (wide open throttle).
-demetrius
DAEDALUS
Yeah, throttle body...keep the pedal down just like demcj said.
