fiznat »
https://forums.nicoclub.com/fiznat-u1372.html
Tue May 20, 2003 7:28 pm
As some of you may know from my other thread, I'm gonna be checking out a car tomorrow (Wed) that I might buy. I really would like to test the compression of each cyl before I buy it, but I'm not too sure on one of the procedures.
1. I understand from the 240sx.org faq that I need to release fuel pressure. How do I do this? After I do that, how do I restore pressure once I'm done testing?
2. What do the plugs look like on the twin cam KA? Are they recessed deep within the valve cover like they are in Saturns? I'm only asking to find out if I'm gonna need an extra deep socket to get it out or what? Hopefully someone can point me in the right direction here... what other tools do I need? (I have a compression tester already- but its not the screw in kind, you just press it on and it'll read- like a little rubber cone keeps the seal) I imagine just the socket set and the tester (and whatever it takes to release fuel pressure?) will be fine?
3. Anything else I should know about this? I know all about the numbers and comparing them and all that, I'm just talking about technical step by step procedures to get it done...
Anyways please if you know how to do this, let me know right away- I'm leaving to check out the car at 12pm on Wed.... HELP!!
