JonPowell »
https://forums.nicoclub.com/jonpowell-u5113.html
Sat Oct 02, 2004 12:07 pm
Actually, according to the manual the engine should be sufficiently warmed. The fuel pump fuse should be pulled, the connector to the injectors should be unplugged. Throttle should be wide open.
The compression should be 174PSI@300RPM with 131PSI@300RPM as the minimum and variance between all 6 should be no more than 14PSI across the board.
The number IS important. Yours fall within specs, but if you were to warm the engine it would probably go up a little more.
