Compression Test
CyanideSX
I picked up my S14 couple of month ago and started doing small stuff here and there. Decided to do the compression test and this is what I got:
1 - 2152 - 2103 - 2104 - 205
Now i thought the numbers were high so a week later i re-did it (thought I messed something up the first time) and got same numbers.
What do you think ? Is this normal ? This is my first project and I learn as I go.
Thanks in advance.
PS. The car has 190k miles on the motor.
Tyler
Car: 1989 240sx HB/1992 240sx coupe/1998 s14
did you test it hot or cold?
CyanideSX
The car was warmed up.
r3v_v3ng3
Car: 91 fastback ka-t
probably carbon build up. unless you have a high comp pistons
TheOne
Car: 93 240sx FB
i've seen this on 2 or 3 other s14 motors, either carbon buildup or milled head.
480sx
Car: 1996 Pearl White 240sx
Your engines in pretty damn good shape for 190k.
CyanideSX
Thank you guys for the replies. Now, my next question ..... Seems like carbon build up should be the easiest to check/try to get rid of. Should I seafoam it and see if it gets rid of it, or does anyone know of any other ways ??
Thanks.
NateDogg
One time I accidentally ran a coolant line to a vacuum source. It smoked pretty good. I pulled the head off a year later and the pistons were perfect.
Maybe a steam cleaning would be a last resort lol...
Yah try seafoam for now and see if that helps.May want to pour a bit into each cylinder after it has warmed up to help soak in and penetrate the carbon. While it's running, just let it suck in through the IACV hose or the 1/8" line back of the intake manifold/fuel pressure regulator.
