compression test
musicmaniac
i am buying a motor sat and wondered if it is possible to do a compression test with the engine outside the car
corn322
Car: 1993 240sx
you just gotta hook everything up the engine needs to run. except gas, you don't need to hook up a fuel line. just make sure it won't fall over when you crank it.
