Rucca »
https://forums.nicoclub.com/rucca-u71259.html
Tue Apr 29, 2008 3:13 pm
Your numbers are low but relatively even. Assuming you did the test right, I would not turbo that car. Be sure you conduct your test with the throttle wide open on a warm engine. Also, add oil to the cylinders and do a second test. If oil causes the numbers go up the problem is in the bottom end, if they stay the same it's a top end problem.
Oil pressure spec at hot idle is 11psi.
Edit: Actually I just read it says "more than 11psi" so I guess you are ok there.
Modified by Rucca at 6:23 PM 4/29/2008
