Compression Test...
RPS13 Rocket
Car: 93 Infiniti J30
Going to look at a car tomorrow, wanted to know about tips that can be shared on doing the compression test. And what the prefered method would be.
corn322
Car: 1993 240sx
this is how I did it1-->
do it while the engine is warm1.release fuel pressure (keep fuel pump fuse out)2.unplug all spark plugs3.screw in tester into plug #1 hole4.floor throttle, turn key and let engine turn over untill needle on the tester stops going any higher. don't run for more than 30 seconds.5.release pressure from tester6.repeat 4 and 5 for the other plug holes
Touchdown038
Car: Computers, cars, sports
Do what corn said, except only let the needle bump up 5 or 6 times. And make sure you ground the coil wire with one of your plugs so you don't accidentally ignite the fumes coming out of the empty spark plug holes.
humpy012
Car: Mark VIII
or if the sparkplugs are out they wont be sparking, if they are disconnected
corn322
Car: 1993 240sx
yeah, I forget to mention I unplugged the ground wire for the coil. I left it in and had my friend hold the tester so I could see it. he got a nasty shock. it was pretty funny.
YomnyM
what compression should it read on the cylinders, whats good, bad and average. Thanks
toki
Just be careful not to misthread, if it seems like it didn't take long enough to stopped early, take it out, do it again. That happend just a few days ago on my friends car when we were doing it and we had to cut the hose and use a ratchet to get it out. $25 down the drain. Oh well. Just be careful and be safe.
C-Kwik
corn322 wrote:this is how I did it1-->
I would just disconnect the fuel injector harness from each injector rather than relieving fuel pressure. I'm assuming this is a 240sx of course since they are easy to get to. It will also ensure no fuel reaches the cylinders.
Touchdown038
How do you go about doing that? Do they just pull straight out?
quiksilvia
Car: 95 s14 se
YomnyM wrote:what compression should it read on the cylinders, whats good, bad and average. Thanks
YomnyM
bro i did search and thats how i got to this thread, damn, is it so hard to type down 9 numbers, thanks anyways, hope you could find the same help in the future.
Touchdown038
Last time I checked it's 12 numbers - 3 for each of the 4 cylinders. 3 x 4 = 12 :)
quiksilvia
Car: 95 s14 se
im not ur bra...
quiksilvia
Car: 95 s14 se
and he did a geo metro swap, so he only has 3 cylinders
YomnyM
well if you read before you talked i ask for what would be a good compression an average and a poor, ex. 185, 175, 155. thats nine numbers, isn't it? lol nice, about the metro swap, i could tell you have no life, you're the only one responding.
quiksilvia
Car: 95 s14 se
i have a life, someone has to make fun of the poor defenseless noo-b's on nico....and i have taken that role.
4felix20
Car: Emerald Blue S14
Quote »192psi (standard)142psi (minimum)14psi difference limit between cylinders
-demetrius[/quote]
NISTECH
here ya go quicksilvia got the info for ya
How to remove a Metro engine.step 1 place your left foot in the right front corner of the engine compartment on the inner fender well.step 2 place your right foot on the front bumper near the license plate.step 3 Grab the intake manifold with your left hand near the front.step 4 Grab the exhaust manifold with your right hand near the rear of the engine.step 5 Slide the engine to the right of the car off the trans input shaft and lift. step 6 Place engine on upper radiator support and climb off of car and take engine to engine stand.
took me like 30 mins to get my 3 cyl engine out of my metro.
LOL HA HA.........HA
4felix20
i drove a 3 cylinder metro cross-country...twice. seriously :puke
