c-rad »
https://forums.nicoclub.com/c-rad-u19918.html
Sat Feb 25, 2006 9:12 pm
According to the FSM, standard compression is 171psi @ 350rpmThe service limit is 142psi @ 350rpm
So according to the FSM service specifications, you are in need of a rebuild. Try pouring a little bit of oil into the spark plug hole before you test the compression. If the compression goes up, your rings are worn. If it doesn't, you can suspect something in the head, but with all 4 low like that, it sounds like some bad rings to me.
