t.mcginley.jr wrote:
If you do end up with fairly low numbers, you can get new head gaskets, but there's no need to get lifters, they don't affect compression at all
I wouldn't consider a new head gasket unless an entire bank is much lower compression than the other. A compression test won't give the overall diagnostic - a cylinder leakdown test is a much better tool you can use to determine if it's a bad valve guide, cracked block, piston rings, etc.
leaking valve cover is not going to affect compression numbers, but you should re-seal it with rtv to prevent oil leaks anyways. that's a good time to buy the "half moon" plugs as well.
