blubottlemax »
https://forums.nicoclub.com/blubottlemax-u3386.html
Sun Jan 09, 2005 5:50 pm
Alright, yesterday I decided to do a compression test on my motor before I start throwing my turbo stuff on. The motor is a 95 with 72k on it. I got 175-180 on 1,3,&4. On 2, I was only getting about 155 at first, but I don't think I had it cranking long enough. After cranking it a little longer than the other cylinders, it too was at 175. If anyone knows, is it bad if you need to crank it over 6-7 times before you reach max compression? The rest of the cylinders maxed out at 4-5 cranks, but #2 took 6-8 before it topped out. Motor was hot and throttle plate was open. I had a concern, because I get occasional overheating (1 time in the last month) and can't seem to get all the air out of the system. I was concerned that maybe the head gasket was leaking, and it might still be, but the compression test didn't show anything negative, and neither do my oil or radiator fluid. Any thoughts on this appreciated.
