deviousKA »
https://forums.nicoclub.com/deviouska-u9381.html
Tue Jun 22, 2004 3:41 pm
Its pretty much impossible to decipher the compression ratio of an engine from the actual compression pressure (to do it accurately). With my kaE at 10.5:1 CR, i get same compression results as you. Cam, and cam timing have a lot to do with what you will get for pressure.
Looks pretty good tho, didnt you just rebuild it? Are you unsure as to which pistons you have?
