red240ne wrote:it's an 89 and the standard compression in the FSM is 192. The minimum compression it lists is 142, so I wouldn't say that 145 is average.
But, there are two versions of the 89. I'm just wondering if yours is the higher compression model.
I've always thought it odd that the SOHC FSM lists standard compression at 192. S14's are only listed at 179 as standard. But, the average figure of 140 - 170 leans more towards most SOHC's being 8.6:1 compression.
You do know that there are other factors in your compression rating such as oil quality and weight, and starter cranking power.... the numbers could be skewed towards a lower side because of such factors. Maybe a leakdown test would give you a better idea of how worn/ out of shape your motor is?
